Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Placing the device on its back with the BRV-HD logo facing up, remove the eight 5mm hexagon 2.0 screws on the front panel.
Lift the front panel off of the speaker using a plastic opening tool.
Placing the device with the back panel facing up, remove the eight 5mm hexagon 2.0 screws from the back panel.
Lift the back panel off of the device with a plastic opening tool.
Turning the device on its side, unscrew the four 15mm hexagon 2.0 screws on the charging port panel.
Remove the outer rubber flap and the plastic side port panel.
Place the device on its front.
Loosen the four 12mm Phillips screws in the four corners with a J1 screwdriver.
Loosen the two 8mm Phillips screws in the center with a J1 screwdriver.
Pull off the rubber sleeve surrounding the speaker using your hands.
Lift the black covering off of the speaker using both hands.
Remove the four 12mm Phillips screws securing the two battery brackets with a J1 screwdriver.
Remove the two brackets that hold down the battery using your hands.
Use the plastic opening tool to lift up the battery.
Remove the battery using your hands.
Disconnect the wire attaching the battery to the motherboard.
Disconnect the three plugs attached to the plastic charging port panel.
Remove and replace the plastic panel with a new one.
2 farklı kişi bu kılavuzu tamamladı.
3 Yorum
BRV-HD Bluetooth board parts
BRV-HD Bluetooth broad parts
