Ana içeriğe geç
Brentwood TS-292B Bread Grabber Spring Replacement
Neye ihtiyacın var
  1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: adım 1, 2 resimden 1. Brentwood TS-292B Bread Grabber Spring Replacement, Bread Grabber Spring: adım 1, 2 resimden 2.
    • Turn the toaster upside down.
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  2. Brentwood TS-292B Bread Grabber Spring Replacement: adım 2, 2 resimden 1. Brentwood TS-292B Bread Grabber Spring Replacement: adım 2, 2 resimden 2.
    • Grasp the plastic pull lever cover firmly and pull to remove it. This may require force.
    • Lift the cover upwards to remove it.
    • When removing the cover, do not damage the cable connector bundle that attaches the cover to the toaster.
  3. Brentwood TS-292B Bread Grabber Spring Replacement: adım 3, 1 resimden 1.
    • To detach the bundled cable connector, carefully pull it away from the circuit board.
  4. Brentwood TS-292B Bread Grabber Spring Replacement: adım 4, 2 resimden 1. Brentwood TS-292B Bread Grabber Spring Replacement: adım 4, 2 resimden 2.
    • Pull the toaster lever down.
    • While holding the toaster lever down, use the spudger to pull the metal tabs away from the wired bread grabber.
    • Continuing to hold the toaster lever down, pinch the wires inward and pull up to carefully remove them from the toaster.
Sonuç
Elly Ayala
739 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 379
