Ana içeriğe geç
Brentwood TS-292B Browning Dial Circuitboard Replacement
Neye ihtiyacın var
  1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: adım 1, 3 resimden 1. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: adım 1, 3 resimden 2. Brentwood TS-292B Browning Dial Circuitboard Replacement, Browning Dial Circuitboard: adım 1, 3 resimden 3.
    • Remove the five screws indicated using a Philips head screwdriver.
  2. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 2, 2 resimden 1. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 2, 2 resimden 2.
    • Pull hard on the browning lever until it detaches from the toaster.
    • It will take some force to pull it off.
    • Once the tab is off, lift up on the housing to remove it from the toaster.
  3. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 3, 1 resimden 1.
    • Once the housing has been pulled upwards, carefully uplug the wire connecting the browning dial circuit board to the main circuit board.
  4. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 4, 2 resimden 1. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 4, 2 resimden 2.
    • There are four screws on the circuit board for the browning dial.
    • Unscrew each of them with a Philips head screwdriver to detach the board and remove the board and dial from the toaster housing.
  5. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 5, 2 resimden 1. Brentwood TS-292B Browning Dial Circuitboard Replacement: adım 5, 2 resimden 2.
    • There are two holes on the board where the pin from the browning dial can align.
    • Refer to the images if you are having trouble finding them.
    • Replace the browning dial by inserting the pin on the dial into one of the holes indicated.
    • Replace the entire circuit board if need be.
Sonuç
Elly Ayala
739 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 219
