Ana içeriğe geç
Brentwood TS-292B Power Cable Replacement
Neye ihtiyacın var
  1. Brentwood TS-292B Power Cable Replacement, Power Cable: adım 1, 1 resimden 1.
    • Remove the five 6mm screws on the bottom of the toaster with a Phillips #2 screw driver.
  2. Brentwood TS-292B Power Cable Replacement: adım 2, 1 resimden 1.
    • To remove the toasting lever, pull the lever away from the toaster.
  3. Brentwood TS-292B Power Cable Replacement: adım 3, 1 resimden 1.
    • Unplug the wire connecting the casing to the circuit board to fully remove the toaster casing.
  4. Brentwood TS-292B Power Cable Replacement: adım 4, 1 resimden 1.
    • Unscrew the wire bracket with a Phillips #2 screw driver.
  5. Brentwood TS-292B Power Cable Replacement: adım 5, 1 resimden 1.
    • Pull back on the black tab that is holding the circuit board in place.
    • While pulling the tab back, lift up on the circuit board.
  6. Brentwood TS-292B Power Cable Replacement: adım 6, 1 resimden 1.
    • Desolder the power wire connections on the circuit board.
    • Desolder in a well ventilated area.
    • The tip of soldering iron is hot handle with caution.
Sonuç
Elly Ayala
739 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 147
