Ana içeriğe geç
Brentwood TS-292B Toasting Lever Replacement
Neye ihtiyacın var
  1. Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: adım 1, 2 resimden 1. Brentwood TS-292B Toasting Lever Replacement, Toasting Lever: adım 1, 2 resimden 2.
    • Use a Phillips #2 screwdriver to remove all of the 6mm screws from the bottom of the toaster.
  2. Brentwood TS-292B Toasting Lever Replacement: adım 2, 3 resimden 1. Brentwood TS-292B Toasting Lever Replacement: adım 2, 3 resimden 2. Brentwood TS-292B Toasting Lever Replacement: adım 2, 3 resimden 3.
    • Push in the small tab located to the left, and pull the lever tab away from the toaster with force.
    • Remove the toaster cover carefully.
  3. Brentwood TS-292B Toasting Lever Replacement: adım 3, 1 resimden 1.
    • Detach the bundled cable connector by carefully pulling it away from the circuit board.
  4. Brentwood TS-292B Toasting Lever Replacement: adım 4, 2 resimden 1. Brentwood TS-292B Toasting Lever Replacement: adım 4, 2 resimden 2.
    • Push the tabs in and lift the top of the toaster off.
  5. Brentwood TS-292B Toasting Lever Replacement: adım 5, 3 resimden 1. Brentwood TS-292B Toasting Lever Replacement: adım 5, 3 resimden 2. Brentwood TS-292B Toasting Lever Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Lift up the tab that is located at the front of the toasting lever.
    • Use tweezers to carefully lift up the metal bar.
    • Remove the springs and replace them with new ones.
Sonuç
Elly Ayala
739 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 14
Her zaman: 580
