Ana içeriğe geç
Breville BKC600XL Heating Tank Replacement
Neye ihtiyacın var
  1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: adım 1, 3 resimden 1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: adım 1, 3 resimden 2. Breville BKC600XL Heating Tank Replacement, Bottom Cover #1: adım 1, 3 resimden 3.
    • Use a Phillips #0 screwdriver to remove the following ten screws:
    • Four 18mm Phillips screws.
    • Four 9.75mm Phillips screws.
    • Two 8mm Phillips screws.
    • The cover will not remove entirely. Keep green ground wire attached to the cover.
  2. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: adım 2, 2 resimden 1. Breville BKC600XL Heating Tank Replacement, Black Water Inlet: adım 2, 2 resimden 2.
    • Remove the two 14.5 Phillips screws.
    • Ensure that only the water inlet valve can be moved.
  3. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: adım 3, 2 resimden 1. Breville BKC600XL Heating Tank Replacement, Bottom Cover #2: adım 3, 2 resimden 2.
    • Use a Phillips #0 screwdriver to remove the following six screws:
    • Six 14.5mm Phillips screws.
  4. Breville BKC600XL Heating Tank Replacement, Power Cord: adım 4, 2 resimden 1. Breville BKC600XL Heating Tank Replacement, Power Cord: adım 4, 2 resimden 2.
    • Remove the power cord from the groove. (the black cord that leads into the green wire.)
    • This creates more slack in the wire to give you more room to work with.
    • DO NOT remove green wire from the cover its attached to.
  5. Breville BKC600XL Heating Tank Replacement, Clear Hose: adım 5, 2 resimden 1. Breville BKC600XL Heating Tank Replacement, Clear Hose: adım 5, 2 resimden 2.
    • Identify the hose that connects to the heating tank. (Observe that it is held up on a small hook.)
    • Push down on the hook and carefully move the hose from its grip.
  6. Breville BKC600XL Heating Tank Replacement, Heating Tank: adım 6, 1 resimden 1.
    • Carefully pull out the heating tank by hand.
    • The heating tank may still be hot. Exercise caution when grabbing hold of the tank. If necessary, wait four to six hours after last use.
    • Reminder for reassembly; You will need a new band to tie the hose back to the heating tank.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Antonio
120 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G3
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 24
Her zaman: 4,598
