Ana içeriğe geç
Breville BKC600XL Water Valve Replacement
Neye ihtiyacın var
  1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: adım 1, 3 resimden 1. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: adım 1, 3 resimden 2. Breville BKC600XL Water Valve Replacement, "Bottom" Black Shell Piece: adım 1, 3 resimden 3.
    • Remove the two 12mm black Phillips screws using a Phillips #0 screwdriver.
    • Reminder for reassembly; This bottom piece is first to be screwed back on.
  2. Breville BKC600XL Water Valve Replacement, "Top" Black Shell Piece: adım 2, 1 resimden 1.
    • Remove the two 12mm Phillips screws using a Phillips #0 screwdriver.
  3. Breville BKC600XL Water Valve Replacement, Silver Casing: adım 3, 3 resimden 1. Breville BKC600XL Water Valve Replacement, Silver Casing: adım 3, 3 resimden 2. Breville BKC600XL Water Valve Replacement, Silver Casing: adım 3, 3 resimden 3.
    • Remove the grey plastic casing.
    • Remove the two 12mm hexagonal screws using a 1.5mm hex screwdriver.
  4. Breville BKC600XL Water Valve Replacement, Water Valve: adım 4, 1 resimden 1.
    • Cut the band connecting the hose to the water valve.
    • Remove the water valve.
    • Reminder for reassembly; You will need a new band to tie the hose back to the water valve.
Sonuç
Antonio
135 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-3, Propen Fall 2012 Cal Poly, Team 1-3, Propen Fall 2012 üyesi
CPSU-PROPEN-F12S1G3
4 Üyeler
18 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can I buy a new water valve assembly? Are they custom to the device or generally available ? Thanks!
Betsy Goodrich - Yanıt
Hi same question :)
Aiqui2@hotmail.com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 5,954
