Ana içeriğe geç
Briggs and Stratton 675 Series Repair Air Filter Replacement
Neye ihtiyacın var
  1. Briggs and Stratton 675 Series Repair Air Filter Replacement, Air Filter: adım 1, 1 resimden 1.
    • Make sure the the engine is off and the spark plug wire is removed and away from the spark plug before beginning.
    • Use a Flathead #4 screw driver to remove the 40mm screw that holds the air filter case in place.
  2. Briggs and Stratton 675 Series Repair Air Filter Replacement: adım 2, 1 resimden 1.
    • Use your hands to pull the air filter case out of the hinge at the bottom.
  3. Briggs and Stratton 675 Series Repair Air Filter Replacement: adım 3, 1 resimden 1.
    • Simply remove the air filter with your hands.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Taichi Nakahara
397 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G31
4 Üyeler
14 adet Kılavuz yazıldı
2 Yorum
Good information, although it didn't resolve my issue. Thanks for sharing
all2thegoodpromo - Yanıt
This is a power wash motor water will not come out
hdoggett Doggett - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 62
Son 30 gün: 251
Her zaman: 19,483
