Ana içeriğe geç
Briggs and Stratton 675 Series Spark Plug Replacement
Neye ihtiyacın var
  1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: adım 1, 2 resimden 1. Briggs and Stratton 675 Series Spark Plug Replacement, Cap Removal: adım 1, 2 resimden 2.
    • Make sure the engine is turned off before beginning.
    • Use your hands to remove the spark plug wire. It should pop off easily with little effort
  2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: adım 2, 3 resimden 1. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: adım 2, 3 resimden 2. Briggs and Stratton 675 Series Spark Plug Replacement, Spark Plug Removal: adım 2, 3 resimden 3.
    • Use a socket wrench with a 13/16" hex bit to unscrew the spark plug from the engine. You will probably need to use a long hex bit in order to get to the bolt.
    • Pull the spark plug out of its housing with your hands.
    • Alternatively, you may use a wrench or pliers to remove the spark plug instead. (Shown in the second image.)
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Andrew Saunders
1.056 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-31, Amido Winter 2015 Cal Poly, Team 6-31, Amido Winter 2015 üyesi
CPSU-AMIDO-W15S6G31
4 Üyeler
19 adet Kılavuz yazıldı
14Kılavuz Yorumları
I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Yanıt
Any ideas I have a Briggs and Stratton engine on my lawn mower but can't get at the spark plug as there is some kind of black plastic housing in front of it.
penora - Yanıt
pinch the front of black cap and pull off
tracy.mullen - Yanıt
What size spark plug does this 675 series lawn mower take, I didn't see it listed?
Eris - Yanıt
just remove the plug and take it with you
when buying a new plug
Bill -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 44
Son 30 gün: 157
Her zaman: 51,599
