Ana içeriğe geç
Giriş
The battery is essential and can wear out or stop working over time. This guide will show you how to properly remove it.
Tech Tip: this Replacement guide will require the use of a soldering iron to remove solders, so check out the soldering guide if you're unfamiliar with the process.
  1. Remove three 8mm screws from the left side of the device. Remove four 8mm screws from the right side of the device. Remove four 8mm screws from the right side of the device.
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Apply pressure on the SD card to pop it out of the port. Remove the card by pulling it out. Remove the card by pulling it out.
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Press down on the top cover of the device and slid it towards you until you see a slight gap created. Lift the top cover off. Lift the top cover off.
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  5. Slide the body case back away from the bottom. Pull up the body case to remove it from the bottom. Pull up the body case to remove it from the bottom.
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  6. Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver. Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  7. Lift the motherboard out of the casing. Lift the motherboard out of the casing.
    • Lift the motherboard out of the casing.
  8. Flip the motherboard over. Desolder the two solder joints and remove the melted solder.
    • Flip the motherboard over.
    • Desolder the two solder joints and remove the melted solder.
    • Beware of over heating the soldering kit will damage the logic board.
  9. Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it). Pull the battery from the motherboard. Pull the battery from the motherboard.
    • Apply the desoldering pump to remove the melted part from the motherboard (press the button to release it).
    • Pull the battery from the motherboard.
Sonuç
Tuong Ngo
85 İtibar
1 Kılavuz yazıldı
Takım
USF Tampa, Team S17-G6, Boczar Spring 2018 USF Tampa, Team S17-G6, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 164
