Ana içeriğe geç
Brightsign 4k Motherboard Removal
Neye ihtiyacın var
  1. Brightsign 4k Motherboard Removal, Outer Shell: adım 1, 3 resimden 1. Brightsign 4k Motherboard Removal, Outer Shell: adım 1, 3 resimden 2. Brightsign 4k Motherboard Removal, Outer Shell: adım 1, 3 resimden 3.
    • Remove three 8mm screws from the left side of the device.
    • Remove four 8mm screws from the right side of the device.
  2. Brightsign 4k Motherboard Removal: adım 2, 3 resimden 1. Brightsign 4k Motherboard Removal: adım 2, 3 resimden 2. Brightsign 4k Motherboard Removal: adım 2, 3 resimden 3.
    • Apply pressure on the SD card to pop it out of the port.
    • Remove the card by pulling it out.
  3. Brightsign 4k Motherboard Removal: adım 3, 3 resimden 1. Brightsign 4k Motherboard Removal: adım 3, 3 resimden 2. Brightsign 4k Motherboard Removal: adım 3, 3 resimden 3.
    • Press down on the top cover of the device and slid it towards you until you see a slight gap created.
    • Lift the top cover off.
  4. Brightsign 4k Motherboard Removal: adım 4, 3 resimden 1. Brightsign 4k Motherboard Removal: adım 4, 3 resimden 2. Brightsign 4k Motherboard Removal: adım 4, 3 resimden 3.
    • Slide the body case back away from the bottom.
    • Pull up the body case to remove it from the bottom.
  5. Brightsign 4k Motherboard Removal, Motherboard Removal: adım 5, 2 resimden 1. Brightsign 4k Motherboard Removal, Motherboard Removal: adım 5, 2 resimden 2.
    • Remove the four 8mm screws at each corner of the motherboard with a JIS #0 screwdriver.
  6. Brightsign 4k Motherboard Removal: adım 6, 2 resimden 1. Brightsign 4k Motherboard Removal: adım 6, 2 resimden 2.
    • Lift the motherboard out of the casing.
Sonuç
Zackery
347 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S17-G6, Boczar Spring 2018 USF Tampa, Team S17-G6, Boczar Spring 2018 üyesi
USFT-BOCZAR-S18S17G6
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 285
