Ana içeriğe geç
Broan-Nutone NU230BL Filter and Light Replacement
Neye ihtiyacın var
  1. Broan-Nutone NU230BL Filter and Light Replacement, Filter and Light: adım 1, 1 resimden 1.
    • Make sure the fan switch is centered, and the light switch is set to "off" to avoid any injuries.
  2. Broan-Nutone NU230BL Filter and Light Replacement: adım 2, 1 resimden 1.
    • Squeeze both ends of the bulb cover to pop it out of the slots.
  3. Broan-Nutone NU230BL Filter and Light Replacement: adım 3, 2 resimden 1. Broan-Nutone NU230BL Filter and Light Replacement: adım 3, 2 resimden 2.
    • Make sure the lightbulb is cool before handling to avoid burns.
    • Unscrew and remove the lightbulb by turning it counterclockwise.
  4. Broan-Nutone NU230BL Filter and Light Replacement: adım 4, 3 resimden 1. Broan-Nutone NU230BL Filter and Light Replacement: adım 4, 3 resimden 2. Broan-Nutone NU230BL Filter and Light Replacement: adım 4, 3 resimden 3.
    • Twist the latch above the filter clockwise.
    • Slide the filter out by gently pulling it.
  5. Broan-Nutone NU230BL Filter and Light Replacement: adım 5, 3 resimden 1. Broan-Nutone NU230BL Filter and Light Replacement: adım 5, 3 resimden 2. Broan-Nutone NU230BL Filter and Light Replacement: adım 5, 3 resimden 3.
    • Insert the new filter.
    • Rotate the retaining latch counterclockwise to secure the filter.
  6. Broan-Nutone NU230BL Filter and Light Replacement: adım 6, 2 resimden 1. Broan-Nutone NU230BL Filter and Light Replacement: adım 6, 2 resimden 2.
    • Install the new lightbulb and turn it clockwise.
  7. Broan-Nutone NU230BL Filter and Light Replacement: adım 7, 2 resimden 1. Broan-Nutone NU230BL Filter and Light Replacement: adım 7, 2 resimden 2.
    • Reinsert the lightbulb cover by pressing both sides and fitting the cover's tabs into the slots.
Sonuç
Your range hood is good-to-go!
Bir başkası bu kılavuzu tamamladı.
Mahdi M
169 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 26
Her zaman: 801
