Ana içeriğe geç
Broil-King BBQ Heat Indicator Replacement Guide
  1. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: adım 1, 3 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: adım 1, 3 resimden 2. Broil-King BBQ Heat Indicator Replacement Guide, Heat Indicator: adım 1, 3 resimden 3.
    • Gather the tools and parts needed for the repair:
    • Crescent Wrench
    • Scraper
    • Replacement Heat Indicator
    • Be sure that the grill is completely cool and disconnect any gas tanks before beginning the repair.
  2. Broil-King BBQ Heat Indicator Replacement Guide: adım 2, 2 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide: adım 2, 2 resimden 2.
    • Open the lid and then remove the nut securing the heat indicator.
    • Use a crescent wrench to loosen the nut.
    • Continue to unthread the nut with your fingers.
    • Place the nut in a secure location for later use.
  3. Broil-King BBQ Heat Indicator Replacement Guide: adım 3, 2 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide: adım 3, 2 resimden 2.
    • Close the lid.
    • Slide the flat edge of the paint scraper under the existing heat indicator plate to pry the plate loose.
    • Lift the plate up, then off of the predrilled holes.
  4. Broil-King BBQ Heat Indicator Replacement Guide: adım 4, 3 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide: adım 4, 3 resimden 2. Broil-King BBQ Heat Indicator Replacement Guide: adım 4, 3 resimden 3.
    • Push the heat indicator from the back to remove it from the Broilmate plate.
  5. Broil-King BBQ Heat Indicator Replacement Guide: adım 5, 3 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide: adım 5, 3 resimden 2. Broil-King BBQ Heat Indicator Replacement Guide: adım 5, 3 resimden 3.
    • Align the new heat indicator through the front of the plate.
    • Move your thumbs around the plate until the heat indicator is secure.
  6. Broil-King BBQ Heat Indicator Replacement Guide: adım 6, 3 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide: adım 6, 3 resimden 2. Broil-King BBQ Heat Indicator Replacement Guide: adım 6, 3 resimden 3.
    • Align the new heat indicator and plate with the factory drilled holes on the face of the BBQ.
    • Hold the plate in place while opening the lid.
  7. Broil-King BBQ Heat Indicator Replacement Guide: adım 7, 2 resimden 1. Broil-King BBQ Heat Indicator Replacement Guide: adım 7, 2 resimden 2.
    • Retrieve the nut used on the previous heat indicator (remember you put it in a secure location).
    • Thread the nut on the new heat indicator.
    • Use a crescent wrench to finish tightening the nut on the new bolt.
  8. Broil-King BBQ Heat Indicator Replacement Guide: adım 8, 1 resimden 1.
    • Close the lid. You're done!
Sonuç
This simple repair doesn’t take much time, yet is well worth the effort. A working heat indicator provides the necessary information about the temperature to ensure safe food practices, and produce a tasty outcome.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 35
Her zaman: 615
