Ana içeriğe geç
Brother CS6000i Needle Plate Replacement
Neye ihtiyacın var
  1. Brother CS6000i Needle Plate Replacement, Body: adım 1, 2 resimden 1. Brother CS6000i Needle Plate Replacement, Body: adım 1, 2 resimden 2.
    • Remove the five 20 mm Phillips #2 screws on the back of the device.
    • Remove the single 28 mm Phillips #2 screw on the back of the device.
    • Remove the single 23 mm Phillips #2 screw on the back of the device.
  2. Brother CS6000i Needle Plate Replacement: adım 2, 2 resimden 1. Brother CS6000i Needle Plate Replacement: adım 2, 2 resimden 2.
    • Pull the white cover off.
  3. Brother CS6000i Needle Plate Replacement: adım 3, 2 resimden 1. Brother CS6000i Needle Plate Replacement: adım 3, 2 resimden 2.
    • Remove the final screw, a 11 mm Phillips #2.
    • After removing all eight screws, you will have five 2 mm screws, one 28 mm screw, one 23 mm screw, and one 11 mm screw, all of which are Phillips #2.
  4. Brother CS6000i Needle Plate Replacement: adım 4, 3 resimden 1. Brother CS6000i Needle Plate Replacement: adım 4, 3 resimden 2. Brother CS6000i Needle Plate Replacement: adım 4, 3 resimden 3.
    • Slightly pull apart the two halves of the machine, taking care not to strain the attached cables.
    • Unhook the white wires that are connected to the motherboard.
    • Fully separate the two halves.
  5. Brother CS6000i Needle Plate Replacement, Needle Plate: adım 5, 2 resimden 1. Brother CS6000i Needle Plate Replacement, Needle Plate: adım 5, 2 resimden 2.
    • Remove the two screws securing the needle plate with a 4mm flathead screwdriver.
Sonuç
Ava Martinez
448 İtibar
4 adet Kılavuz yazıldı
Ekip
Cuesta, Team 20-1, Krynen Fall 2024 Cuesta, Team 20-1, Krynen Fall 2024 üyesi
CUESTA-KRYNEN-F24S20G1
5 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 14
Her zaman: 198
