Ana içeriğe geç
Brother DCP-L2550DW Toner Cartridge Replacement
Neye ihtiyacın var
  1. Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: adım 1, 2 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement, Toner Cartridge: adım 1, 2 resimden 2.
    • Unplug your printer from the outlet. Identify your printer and the toner cartridge required.
    • The printer recommends only two cartridges, TN-730 and TN-760.
  2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 2, 3 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement: adım 2, 3 resimden 2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 2, 3 resimden 3.
    • Pull on the tab to open the front plate of your printer.
  3. Brother DCP-L2550DW Toner Cartridge Replacement: adım 3, 3 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement: adım 3, 3 resimden 2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 3, 3 resimden 3.
    • Pull on the green handle to remove the drum unit of your printer.
  4. Brother DCP-L2550DW Toner Cartridge Replacement: adım 4, 3 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement: adım 4, 3 resimden 2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 4, 3 resimden 3.
    • Place the drum unit on a clean flat surface.
    • Press down on the green button at the bottom left corner of the drum unit to unlock the toner cartridge.
    • Remove the toner cartridge from the drum unit.
  5. Brother DCP-L2550DW Toner Cartridge Replacement: adım 5, 3 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement: adım 5, 3 resimden 2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 5, 3 resimden 3.
    • Insert the new toner cartridge into the drum unit by placing it on top of the drum unit and pressing it down, ensuring it is in the locked position.
    • Do not touch the ink roll of the cartridge. It can compromise the quality of the ink.
  6. Brother DCP-L2550DW Toner Cartridge Replacement: adım 6, 3 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement: adım 6, 3 resimden 2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 6, 3 resimden 3.
    • Insert the drum unit back into the printer by placing it at the edge of the opening and sliding it inside until it locks in place.
  7. Brother DCP-L2550DW Toner Cartridge Replacement: adım 7, 3 resimden 1. Brother DCP-L2550DW Toner Cartridge Replacement: adım 7, 3 resimden 2. Brother DCP-L2550DW Toner Cartridge Replacement: adım 7, 3 resimden 3.
    • Close the front plate and ensure it is in the locked position.
  8. Brother DCP-L2550DW Toner Cartridge Replacement: adım 8, 1 resimden 1.
    • Replacement completed. Plug the printer back in the outlet and test it out. You can now use your printer.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Syed Momin Raza
157 İtibar
1 Kılavuz yazıldı
1Rehber Yorum
Hi , I’m facing unable to print double sided issue. It able to print on 1 page, but when the paper roll back and ready to print on the other page, it stuck. Could you help me on this?
Shininimi Here - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 43
Her zaman: 334
