Ana içeriğe geç
Brother IntelliFax-2840 Control Panel Replacement
Neye ihtiyacın var
  1. Brother IntelliFax-2840 Control Panel Replacement, Automatic Document Feeder: adım 1, 1 resimden 1.
    • Remove the two 15 mm Phillips #1 screws securing the ADF at the rear of the fax machine.
    FixBot'a Sor
    Yorum Ekle
  2. Brother IntelliFax-2840 Control Panel Replacement: adım 2, 2 resimden 1. Brother IntelliFax-2840 Control Panel Replacement: adım 2, 2 resimden 2.
    • Gently pull the ADF up and away from the machine.
    FixBot'a Sor
    Yorum Ekle
  3. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: adım 3, 2 resimden 1. Brother IntelliFax-2840 Control Panel Replacement, Control Panel: adım 3, 2 resimden 2.
    • Gently lift up the control panel.
    FixBot'a Sor
    Yorum Ekle
  4. Brother IntelliFax-2840 Control Panel Replacement: adım 4, 3 resimden 1. Brother IntelliFax-2840 Control Panel Replacement: adım 4, 3 resimden 2. Brother IntelliFax-2840 Control Panel Replacement: adım 4, 3 resimden 3.
    • Use a finger or prying tool to gently pop off the right side control arm (furthest from the handset).
    • Repeat for the left side control arm.
    • You can make this task easier by taking the handset out of the cradle and setting it aside.
    FixBot'a Sor
    Yorum Ekle
  5. Brother IntelliFax-2840 Control Panel Replacement: adım 5, 2 resimden 1. Brother IntelliFax-2840 Control Panel Replacement: adım 5, 2 resimden 2.
    • Do not attempt to completely remove the control panel yet, as it is still connected by a cable.
    • Lifting from the front edge, gently flip up the control panel.
    FixBot'a Sor
    Yorum Ekle
  6. Brother IntelliFax-2840 Control Panel Replacement: adım 6, 1 resimden 1.
    • While supporting the control panel with one hand, remove the three 12.2 mm Phillips #1 screws securing the rear control panel cover.
    FixBot'a Sor
    Yorum Ekle
  7. Brother IntelliFax-2840 Control Panel Replacement: adım 7, 1 resimden 1.
    • While still supporting the control panel, use your fingers or a spudger to gently free the two plastic clips securing the rear control panel cover.
    • Slide the rear control panel cover down slightly to free it from the three clips along the upper edge.
    FixBot'a Sor
    Yorum Ekle
  8. Brother IntelliFax-2840 Control Panel Replacement: adım 8, 2 resimden 1. Brother IntelliFax-2840 Control Panel Replacement: adım 8, 2 resimden 2.
    • Separate the rear control panel cover from the control panel.
    FixBot'a Sor
    Yorum Ekle
  9. Brother IntelliFax-2840 Control Panel Replacement: adım 9, 2 resimden 1. Brother IntelliFax-2840 Control Panel Replacement: adım 9, 2 resimden 2.
    • Gently pull the control panel cable straight out from its connector.
    • The control panel should now come free.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
92.872 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 4,590
