Ana içeriğe geç
Brother MFC-490CW Front Panel Replacement
Neye ihtiyacın var
  1. Brother MFC-490CW Front Panel Replacement, Remove screws holding the front panel: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: adım 2, 3 resimden 1. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: adım 2, 3 resimden 2. Brother MFC-490CW Front Panel Replacement, Unplug the panel from the rest of the printer: adım 2, 3 resimden 3.
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
Sonuç
To reassemble the front panel, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Matt
64 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G4
3 Üyeler
11 adet Kılavuz yazıldı
1Rehber Yorum
Be sure the three plastic tabs on the bottom of the black front cover are inserted fully when you snap the cover back into place or else you will get a message saying the ink door is not closed.
Raymond Rinaldi - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,824
