Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
If none of the functions on the device is working, the motherboard may need to be replaced, particularly if the device experienced an electrical surge that overloaded the motherboard.
Neye ihtiyacın var
Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
Lift up the front panel from the device.
Gently lift up and disconnect the data cables that attach the panel to the printer.
Lift the scanner unit.
Gently twist the top portion of the arm. The top portion should release from the scanner unit.
Rotate the arm approximately 45 degrees to remove the bottom portion of the arm from the device.
Slide the unit either to the left or right and begin the push the unit away from the device.
Once one hinge is separated from the device, begin to remove the other hinge from device.
Gently place the unit on the work surface.
From the back of the device, use the expose portion of the panel and gently begin to remove the panel away from the device.
From the back of the device, use the exposed portion of the panel to begin to lift the panel away from the device.
Remove the three power cables that connect the scanner to the motherboard.
Gently pull the data away from the motherboard.
Slide the cable out of the slots to remove the cable from the device.
The scanner unit is now separated. Place the unit and ground screw in a safe part of the workspace until needed for re-assembly.
Unscrew the three 14.1mm screws.
Unscrew the 12.1mm screw.
Unscrew the 8mm screw at the center of the device.
Gently push the upper-left tab of the cover and separate the hinged portion of the cover from the rest of the device.
Once one side of free, slide the other side away from the device.
Pull the cover away from the device.
Using a spudger, loosen the two clipped portions of the cover located at the back-center of the device.
Once the clips are free the rest of the cover can be lifted up and away from the device.
Push the left and right clipped portion of the cover away from the device.
Unscrew the three 8.3mm screws from the mother cover.
Lift the cover away from the device. Be careful, the cover may get stuck from the Ethernet port. Simply slide the cover until it clears the port.
Gently pull the five power cables away from the motherboard.
Gently lift the five power cables away from the motherboard.
Squeeze the clips of the cover protecting the orange cable.
Lift the cover away from the motherboard and set is aside.
Gently lift the orange power cable away from the motherboard.
Unscrew the four 12.1mm screws.
Lift the motherboard away from the rest of the device.
2 farklı kişi bu kılavuzu tamamladı.
2 Yorum
How Did you program the new mainboard with serial # and other info???
Also works for DCP J715W and probably others since they all look alike.
(Don’t try to pry open the front panels on the DCP J715W. It’s just for decorative purpose, and I broke the one-way plastic clips trying to remove them. The rule seems to be “If you don’t see a screw to remove a part, it’s that you didn’t find it yet” (All meaningful “one-way plastic clips” I found were easily accessible))
