Ana içeriğe geç
Brother MFC-490CW Scanning Glass Replacement
Neye ihtiyacın var
  1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: adım 1, 3 resimden 1. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: adım 1, 3 resimden 2. Brother MFC-490CW Scanning Glass Replacement, Removing Scanner Header: adım 1, 3 resimden 3.
    • Twist green section to allow the scanner head to have a full range of motion.
  2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: adım 2, 3 resimden 1. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: adım 2, 3 resimden 2. Brother MFC-490CW Scanning Glass Replacement, Removing Scan Header: adım 2, 3 resimden 3.
    • To remove scanner head, open it halfway as possible and slide the hinges out of place and the head will be removed.
  3. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: adım 3, 3 resimden 1. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: adım 3, 3 resimden 2. Brother MFC-490CW Scanning Glass Replacement, Remove scanner head connection to printer: adım 3, 3 resimden 3.
    • The panels to expose the cords will become exposed when the head is removed.
    • Pull all colored cords from the printer and unscrew the other wire to be fully removed.
    • Pull the black tab from the printer to remove.
  4. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: adım 4, 2 resimden 1. Brother MFC-490CW Scanning Glass Replacement, Removing the bottom screws: adım 4, 2 resimden 2.
    • Once scanner is free from the printer remove all the screws on the bottom base
    • Use a #2 Philips head screw driver to remove the two 12.1mm screws.
  5. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: adım 5, 3 resimden 1. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: adım 5, 3 resimden 2. Brother MFC-490CW Scanning Glass Replacement, Exposing scanner glass: adım 5, 3 resimden 3.
    • To separate the base from the glass hold upright and separate along the edge where you removed the screws.
    • Use hands to expose the glass.
    • Keep track flat once glass is removed as to not lose little parts.
  6. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: adım 6, 3 resimden 1. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: adım 6, 3 resimden 2. Brother MFC-490CW Scanning Glass Replacement, Replacing scanner glass: adım 6, 3 resimden 3.
    • Disconnect the glass from the tracks.
    • Remove old or broken glass.
    • Replace with adhesive tape along the bottom of the header and reassemble.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
George Kielpinski
50 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G4
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 93
Her zaman: 4,584
