Ana içeriğe geç
Brother MFC-490CW Wireless module Replacement
Neye ihtiyacın var
  1. Brother MFC-490CW Wireless module Replacement, Remove screws holding the front panel: adım 1, 1 resimden 1.
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: adım 2, 3 resimden 1. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: adım 2, 3 resimden 2. Brother MFC-490CW Wireless module Replacement, Unplug the panel from the rest of the printer: adım 2, 3 resimden 3.
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Wireless module Replacement, Remove the screw: adım 3, 1 resimden 1.
    • Unscrew the 14.1mm screw located at the left side of the device.
    • Unscrew the 12.1mm screw to the right of the 14.1mm screw.
  4. Brother MFC-490CW Wireless module Replacement: adım 4, 3 resimden 1. Brother MFC-490CW Wireless module Replacement: adım 4, 3 resimden 2. Brother MFC-490CW Wireless module Replacement: adım 4, 3 resimden 3.
    • Pry open the left front panel away from the printer
    • Be careful. The panel is attached with a data cable.
  5. Brother MFC-490CW Wireless module Replacement: adım 5, 2 resimden 1. Brother MFC-490CW Wireless module Replacement: adım 5, 2 resimden 2.
    • Carefully unplug the connector attached to the device.
  6. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: adım 6, 3 resimden 1. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: adım 6, 3 resimden 2. Brother MFC-490CW Wireless module Replacement, Remove the module from the panel: adım 6, 3 resimden 3.
    • Separate the two clips that hold the module in place.
    • Lift up the module.
Sonuç
To reassemble your wireless module, follow these instructions in reverse order.
Matt
64 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 4-4, Miles Fall 2014 UMass Dartmouth, Team 4-4, Miles Fall 2014 üyesi
UMASSD-MILES-F14S4G4
3 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 2,188
