Ana içeriğe geç
Brother PT-1010 Battery Replacement
  1. Brother PT-1010 Battery Replacement, Removing Back Panel: adım 1, 1 resimden 1.
    • Turn device so you are looking down at the top
    FixBot'a Sor
    Yorum Ekle
  2. Brother PT-1010 Battery Replacement: adım 2, 2 resimden 1. Brother PT-1010 Battery Replacement: adım 2, 2 resimden 2.
    • Press firmly on arrow indicator and pull panel toward you.
    FixBot'a Sor
    Yorum Ekle
  3. Brother PT-1010 Battery Replacement, Remove Dead Batteries: adım 3, 1 resimden 1.
    • Remove dead batteries one at a time by pulling up on the side indicated with a + symbol.
    • Make sure the battery compartment is empty and clear of debris.
    FixBot'a Sor
    Yorum Ekle
  4. Brother PT-1010 Battery Replacement: adım 4, 2 resimden 1. Brother PT-1010 Battery Replacement: adım 4, 2 resimden 2.
    • Insert the first battery with the flat side (indicated by a - symbol on the battery) facing to the left of the battery compartment.
    • Do the same thing to insert the next 2 batteries.
    FixBot'a Sor
    Yorum Ekle
  5. Brother PT-1010 Battery Replacement: adım 5, 1 resimden 1.
    • The next 3 batteries will be inserted on top of the others.
    • Insert the 4th battery with the flat side (indicated by the - symbol on the battery) facing to the right of the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  6. Brother PT-1010 Battery Replacement: adım 6, 1 resimden 1.
    • Repeat step 5 to insert the last 2 batteries.
    FixBot'a Sor
    Yorum Ekle
  7. Brother PT-1010 Battery Replacement, Replace Back Panel: adım 7, 1 resimden 1.
    • Reinsert back panel.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Haley Sweet
460 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 5,267
