Ana içeriğe geç
Brother PT-1010 Cassette Tape Replacement
Neye ihtiyacın var
  1. Brother PT-1010 Cassette Tape Replacement, Remove Back Cover: adım 1, 1 resimden 1.
    • Remove the back cover of the device by simultaneously pressing down on the indication arrows on the top center, then pulling toward you.
  2. Brother PT-1010 Cassette Tape Replacement, Insert Tape Cassette: adım 2, 1 resimden 1.
    • Brother TZ tape is required for this replacement process. We don't have the tape cassette but you should be able to insert tape cassette into the red marked area as shown in the picture.
    • Insert tape cassette into the red marked area as shown in the picture.
    • Make sure the cassette snaps into place by applying a small amount of pressure.
Sonuç
Haley Sweet
460 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G4
4 Üyeler
3 Yorum
So if you've replaced the cassette and it still won't print now what??
Sara Mullaney - Yanıt
This was supposed to help with model PT-450D which looks nothing like this. Please help. I can’t REMOVE / replace the cassette !!! It is STUCK inside the label printer!
af4k - Yanıt
I have a PT-1880 model and replaced the cassette, but whenever I type something to label something, the label comes out blank. Can someone help me on this? I’ve been needing help on this for a while now.
Yael Rzoque - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 3,289
