Ana içeriğe geç
Brother PT-1010 Cutter Blade Replacement
  1. Brother PT-1010 Cutter Blade Replacement, Remove Back Cover: adım 1, 1 resimden 1.
    • Open the back cover of the device by pressing on the indication arrow and pulling it open.
    FixBot'a Sor
    Yorum Ekle
  2. Brother PT-1010 Cutter Blade Replacement, Locate Cutter Blade Unit: adım 2, 1 resimden 1.
    • Locate the yellow cutter blade unit as shown in the photo.
    FixBot'a Sor
    Yorum Ekle
  3. Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: adım 3, 3 resimden 1. Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: adım 3, 3 resimden 2. Brother PT-1010 Cutter Blade Replacement, Remove Cutter Blade: adım 3, 3 resimden 3.
    • Using your thumb and forefinger, pull up, applying a small amount of pressure until the blade loosens and comes out.
    • Be very careful when pulling out the cutter blade, it is very sharp.
    • The Brother no. TL 5 Cutter Blade Unit is required for replacement.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Haley Sweet
460 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-4, Williams Fall 2014 Baylor, Team 4-4, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G4
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 34
Her zaman: 1,777
