Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Flip the device over and press down on the indication arrows located at the top center of the back cover and pull it open.
Use a phillips size #00 screwdriver to unscrew the 5 corner screws circled in the picture.
Separate the top of the device from the bottom. Be very cautious when you separate the device, there is a ribbon attaching the top to the bottom.
Remove the two black side panels. They will easily fall out so just move them to the side until you are putting your device back together.
Using your index finger and thumb, pull out the golden ribbon from the green circuit board.
Use a phillips size #00 screwdriver to remove the two screws, circled in red, from the green circuit board.
Carefully remove the green circuit board by pulling it straight up. Be careful not to break the LCD cable ribbon that connects the circuit board to the device.
Underneath the circuit board you will find the rubber keyboard. Peel this off and remove it from the device.
3 Yorum
Hi!
Thanks for this very helpful and detailed set of instructions. One small suggestion - assuming that replacing the keyboard means you need a working one to replace the old one with, you might want to consider adding “Parts: replacement keyboard” instead of “No parts required.”
Cheers,
Maria B
Please specify what is being replaced. Is the rubber keyboard the part that needs to be replaced?
Screen is dull, what to do
