Ana içeriğe geç
Brother PT-110 Printer Motor Replacement
Neye ihtiyacın var
    1. Brother PT-110 Printer Motor Replacement, Batteries: adım 1, 2 resimden 1. Brother PT-110 Printer Motor Replacement, Batteries: adım 1, 2 resimden 2.
      • Push on the side of the cover, and remove it.
      FixBot'a Sor
      Yorum Ekle
    2. Brother PT-110 Printer Motor Replacement: adım 2, 1 resimden 1.
      • Remove the batteries.
      FixBot'a Sor
      Yorum Ekle
    1. Brother PT-110 Printer Motor Replacement, Back Plate: adım 3, 2 resimden 1. Brother PT-110 Printer Motor Replacement, Back Plate: adım 3, 2 resimden 2.
      • Unscrew the two 9 mm Phillips #1 screws from the top and bottom.
      • Total: 2 x Screws
      FixBot'a Sor
      Yorum Ekle
    2. Brother PT-110 Printer Motor Replacement: adım 4, 1 resimden 1.
      • First: To separate the top cover from the body, insert a spudger between the two halves.
      • Gently twist the spudger until the two halves separate. Do this in multiple spots around the perimeter of the cover to distribute the pressure.
      • DO NOT PULL HALVES APART. There are wired connections inside that must be disconnected before halves can be fully separated.
      FixBot'a Sor
      Yorum Ekle
    3. Brother PT-110 Printer Motor Replacement: adım 5, 1 resimden 1.
      • Gently separate the two covers, ensuring wires are not taut.
      FixBot'a Sor
      Yorum Ekle
    4. Brother PT-110 Printer Motor Replacement: adım 6, 1 resimden 1.
      • Gently grasp the ribbon wire and top cover, then gently pull the ribbon wire out of its connection.
      FixBot'a Sor
      Yorum Ekle
    5. Brother PT-110 Printer Motor Replacement: adım 7, 2 resimden 1. Brother PT-110 Printer Motor Replacement: adım 7, 2 resimden 2.
      • Carefully pinch the top of the connector.
      • Pull perpendicular to the device until the wire is disconnected.
      • It may require more force than expected to disconnect the wires.
      FixBot'a Sor
      Yorum Ekle
    6. Brother PT-110 Printer Motor Replacement: adım 8, 3 resimden 1. Brother PT-110 Printer Motor Replacement: adım 8, 3 resimden 2. Brother PT-110 Printer Motor Replacement: adım 8, 3 resimden 3.
      • Unscrew the three 9 mm Phillips #1 screws shown.
      • Total: 3 x Screws
      FixBot'a Sor
      Yorum Ekle
    1. Brother PT-110 Printer Motor Replacement, Printer Motor: adım 9, 1 resimden 1.
      • Remove the motor housing.
      FixBot'a Sor
      Yorum Ekle
    2. Brother PT-110 Printer Motor Replacement: adım 10, 2 resimden 1. Brother PT-110 Printer Motor Replacement: adım 10, 2 resimden 2.
      • Unscrew the two 3 mm Phillips #1 screws from the motor housing.
      • Total: 2 x Screws
      FixBot'a Sor
      Yorum Ekle
    3. Brother PT-110 Printer Motor Replacement: adım 11, 1 resimden 1.
      • Remove the motor.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Kimberly Larsen
279 İtibar
5 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-1, Harley Fall 2016 IUPUI, Team 1-1, Harley Fall 2016 üyesi
IUPUI-HARLEY-F16S1G1
3 Üyeler
21 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 28
Her zaman: 1,149
