Ana içeriğe geç
Brother PT-1290 Face Plate Replacement
Neye ihtiyacın var
  1. Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: adım 1, 3 resimden 1. Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: adım 1, 3 resimden 2. Brother PT-1290  Face Plate Replacement, Turn over device to remove batteries.: adım 1, 3 resimden 3.
    • Turn the device to it's side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
  2. Brother PT-1290  Face Plate Replacement, Back of device: adım 2, 3 resimden 1. Brother PT-1290  Face Plate Replacement, Back of device: adım 2, 3 resimden 2. Brother PT-1290  Face Plate Replacement, Back of device: adım 2, 3 resimden 3.
    • Remove back of device and set aside.
  3. Brother PT-1290  Face Plate Replacement, Remove screws: adım 3, 3 resimden 1. Brother PT-1290  Face Plate Replacement, Remove screws: adım 3, 3 resimden 2. Brother PT-1290  Face Plate Replacement, Remove screws: adım 3, 3 resimden 3.
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
  4. Brother PT-1290  Face Plate Replacement, Remove flat panel: adım 4, 3 resimden 1. Brother PT-1290  Face Plate Replacement, Remove flat panel: adım 4, 3 resimden 2. Brother PT-1290  Face Plate Replacement, Remove flat panel: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
  5. Brother PT-1290  Face Plate Replacement, Remove: adım 5, 3 resimden 1. Brother PT-1290  Face Plate Replacement, Remove: adım 5, 3 resimden 2. Brother PT-1290  Face Plate Replacement, Remove: adım 5, 3 resimden 3.
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
  6. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: adım 6, 3 resimden 1. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: adım 6, 3 resimden 2. Brother PT-1290  Face Plate Replacement, Removing the LCD screen.: adım 6, 3 resimden 3.
    • Now that you have removed your keyboard. Turn the device over carefully.
    • Pop of LCD black cover.
    • Use the spudger to gently press out the LCD screen.
  7. Brother PT-1290  Face Plate Replacement, Switching out faceplate.: adım 7, 1 resimden 1.
    • Change out old damaged face plate with your new face plate.
Sonuç
Lorraine Canez
318 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 12
Her zaman: 163
