Ana içeriğe geç
Brother PT-1290 Keyboard Replacement
Neye ihtiyacın var
  1. Brother PT-1290 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Brother PT-1290 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Brother PT-1290 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Turn the device to its side toward the bottom of the keyboard. Then pop open the case and remove the batteries.
    FixBot'a Sor
    Yorum Ekle
  2. Brother PT-1290 Keyboard Replacement: adım 2, 3 resimden 1. Brother PT-1290 Keyboard Replacement: adım 2, 3 resimden 2. Brother PT-1290 Keyboard Replacement: adım 2, 3 resimden 3.
    • Remove back of device and set aside.
    FixBot'a Sor
    Yorum Ekle
  3. Brother PT-1290 Keyboard Replacement: adım 3, 3 resimden 1. Brother PT-1290 Keyboard Replacement: adım 3, 3 resimden 2. Brother PT-1290 Keyboard Replacement: adım 3, 3 resimden 3.
    • Remove all 1/4 inch screws(6 total) with a (+PH00) screwdriver. Open slowly not to damage the display data cable.
    FixBot'a Sor
    Yorum Ekle
  4. Brother PT-1290 Keyboard Replacement: adım 4, 3 resimden 1. Brother PT-1290 Keyboard Replacement: adım 4, 3 resimden 2. Brother PT-1290 Keyboard Replacement: adım 4, 3 resimden 3.
    • Use a plastic opening tool to remove the flat-panel membrane keyboard. Lift up and set aside.
    FixBot'a Sor
    Yorum Ekle
  5. Brother PT-1290 Keyboard Replacement: adım 5, 3 resimden 1. Brother PT-1290 Keyboard Replacement: adım 5, 3 resimden 2. Brother PT-1290 Keyboard Replacement: adım 5, 3 resimden 3.
    • Use a spudger to aid in removing the keyboard.
    • Gently lift out while removing the LCD screen that is connected to the data cable and finishing removing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Angela Araujo
99 İtibar
1 Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G4
3 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 32
Her zaman: 779
