Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Brother PT-1290 Tape Cassette Replacement
  1. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: adım 1, 3 resimden 1. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: adım 1, 3 resimden 2. Brother PT-1290 Tape Cassette Replacement, Removing the back piece of the label maker.: adım 1, 3 resimden 3.
    • Flip the label maker onto its backside and press down on the circle part with ridges located at the top.
    • Gently pull the label maker apart. It will split in half.
    • Be careful with the back part to prevent any damage.
  2. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: adım 2, 3 resimden 1. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: adım 2, 3 resimden 2. Brother PT-1290 Tape Cassette Replacement, Removing batteries or AC adapter.: adım 2, 3 resimden 3.
    • For safety precautions, it is advised that you remove the batteries before trying to remove and replace your tape cassette.
    • If you're using an AC adapter, remove it from the label maker. If using both the adapter and batteries, remove both to turn off your label maker.
  3. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: adım 3, 3 resimden 1. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: adım 3, 3 resimden 2. Brother PT-1290 Tape Cassette Replacement, Replacing tape cassette.: adım 3, 3 resimden 3.
    • When inserting the tape cassette it should snap into place. Check to see if the tape is feeding under the tape guides.
    • If the ribbon becomes loose, use your finger to wind the white wheel in the direction of the arrow on the tape cassette.
    • Only use Brother TZ tapes with this label maker machine.
  4. Brother PT-1290 Tape Cassette Replacement, Evaluating: adım 4, 3 resimden 1. Brother PT-1290 Tape Cassette Replacement, Evaluating: adım 4, 3 resimden 2. Brother PT-1290 Tape Cassette Replacement, Evaluating: adım 4, 3 resimden 3.
    • Now that you have inserted the tape, the batteries may be added back. Close the label maker, press the power button, then it is ready for use.
    • If you're using an AC adapter or both batteries/AC adapter, make sure the AC adapter is plugged into the AC outlet. Then plug the other end of the AC adapter in to the outlet on the top corner of the device. Also, check that your batteries are placed correctly.
  5. Brother PT-1290 Tape Cassette Replacement, Feeding Tape.: adım 5, 2 resimden 1. Brother PT-1290 Tape Cassette Replacement, Feeding Tape.: adım 5, 2 resimden 2.
    • After installing the tape press the up key to feed the tape, then the cutter button to cut the tape off.
Sonuç
Lorraine Canez
318 İtibar
3 adet Kılavuz yazıldı
Ekip
Gateway, Team 1-4, Johnson Fall 2014 Gateway, Team 1-4, Johnson Fall 2014 üyesi
GCC-JOHNSON-F14S1G4
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Wie wird die Kassette eingesetzt
Uwe Seiler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 32
Her zaman: 19,733
