Ana içeriğe geç
Brother PT-210 Back Case Opening
Neye ihtiyacın var
  1. Brother PT-210 Back Case Opening, Back Cover: adım 1, 3 resimden 1. Brother PT-210 Back Case Opening, Back Cover: adım 1, 3 resimden 2. Brother PT-210 Back Case Opening, Back Cover: adım 1, 3 resimden 3.
    • Use the tab to open the back cover of your machine.
  2. Brother PT-210 Back Case Opening, Tape: adım 2, 2 resimden 1. Brother PT-210 Back Case Opening, Tape: adım 2, 2 resimden 2.
    • Remove the tape by grabbing the tape and pulling it up & out of your machine.
  3. Brother PT-210 Back Case Opening, New Tape: adım 3, 1 resimden 1.
    • If you are going to use a new tape, you have to turn the green knob counterclockwise a few times to get the tape ready to use.
  4. Brother PT-210 Back Case Opening, Batteries: adım 4, 3 resimden 1. Brother PT-210 Back Case Opening, Batteries: adım 4, 3 resimden 2. Brother PT-210 Back Case Opening, Batteries: adım 4, 3 resimden 3.
    • Remove all 6 batteries from your machine.
    • When you put the batteries back in, keep in mind that the polarity of them matter. Your machine won't work if the polarities of the batteries are messed up.
    • Do not mix new and old batteries!
    • It might be helpful to take the tape out of your machine. This guide shows you how to.
  5. Brother PT-210 Back Case Opening, Remove Screws: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    Phillips #00 Screwdriver
    $5.49
    • Remove these screws with a Phillips #00 Screwdriver.
    • Don't forget the sneaky ones!
    • When you are opening it, make sure to not damage any of the electronics inside.
Sonuç
TheMasterG
1.406 İtibar
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 84
