Ana içeriğe geç
Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: adım 1, 2 resimden 1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: adım 1, 2 resimden 2.
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
    FixBot'a Sor
    Yorum Ekle
  2. Brother PT-D200 Cutter Blade Replacement: adım 2, 1 resimden 1.
    • Locate the cutter blade unit (mint green) as shown in the picture.
    FixBot'a Sor
    Yorum Ekle
  3. Brother PT-D200 Cutter Blade Replacement: adım 3, 2 resimden 1. Brother PT-D200 Cutter Blade Replacement: adım 3, 2 resimden 2.
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Blaire McCreary
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G16
3 Üyeler
6 adet Kılavuz yazıldı
2Kılavuz Yorumları
Where can you order the replacement blade?
mistymeziere - Yanıt Paylaş
Thank you it, the blade came out and I did not know how to fix this.. found this video and quickly fixed it..
niva - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 94
Her zaman: 4,413
