Ana içeriğe geç
Brother PT-D200 Cutter Blade Replacement
  1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: adım 1, 2 resimden 1. Brother PT-D200 Cutter Blade Replacement, Cutter Blade: adım 1, 2 resimden 2.
    • Open the back panel of the device by pressing down on and then pulling the indication arrows on the top center of the cover upward towards you.
  2. Brother PT-D200 Cutter Blade Replacement: adım 2, 1 resimden 1.
    • Locate the cutter blade unit (mint green) as shown in the picture.
  3. Brother PT-D200 Cutter Blade Replacement: adım 3, 2 resimden 1. Brother PT-D200 Cutter Blade Replacement: adım 3, 2 resimden 2.
    • Using the thumb and forefinger, pull up, applying a moderate amount of pressure until the cutter blade unit loosens and is removed.
    • The blade is sharp.
Sonuç
Blaire McCreary
201 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-16, Regan Winter 2014 Cal Poly, Team 13-16, Regan Winter 2014 üyesi
CPSU-REGAN-W14S13G16
3 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where can you order the replacement blade?
mistymeziere - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 15
Son 30 gün: 43
Her zaman: 3,076
