Ana içeriğe geç
Brother XM3700 Broken Needle Replacement
Neye ihtiyacın var
  1. Brother XM3700 Broken Needle Replacement, Broken Needle: adım 1, 3 resimden 1. Brother XM3700 Broken Needle Replacement, Broken Needle: adım 1, 3 resimden 2. Brother XM3700 Broken Needle Replacement, Broken Needle: adım 1, 3 resimden 3.
    • Adjust the needle with the handwheel towards you until it is at the highest position, as indicated by the silver thread take-up lever.
  2. Brother XM3700 Broken Needle Replacement: adım 2, 2 resimden 1. Brother XM3700 Broken Needle Replacement: adım 2, 2 resimden 2.
    • Unscrew the bolt that holds the needle in place using either the tool that came with your Brother machine, or a small flat object like a coin.
  3. Brother XM3700 Broken Needle Replacement: adım 3, 2 resimden 1. Brother XM3700 Broken Needle Replacement: adım 3, 2 resimden 2.
    • Remove the broken needle stem from the machine, and dispose of it carefully.
  4. Brother XM3700 Broken Needle Replacement: adım 4, 2 resimden 1. Brother XM3700 Broken Needle Replacement: adım 4, 2 resimden 2.
    • Unthread the broken needle tip from the thread, and dispose of carefully.
  5. Brother XM3700 Broken Needle Replacement: adım 5, 2 resimden 1. Brother XM3700 Broken Needle Replacement: adım 5, 2 resimden 2.
    • Select a Brother brand needle, using the needle size that works well with your fabric.
  6. Brother XM3700 Broken Needle Replacement: adım 6, 2 resimden 1. Brother XM3700 Broken Needle Replacement: adım 6, 2 resimden 2.
    • Insert the needle with the flat side of the stem facing the back of the machine.
  7. Brother XM3700 Broken Needle Replacement: adım 7, 1 resimden 1.
    • Screw the bolt in first with your fingers and then with the tool until the needle is tightly secured.
  8. Brother XM3700 Broken Needle Replacement: adım 8, 2 resimden 1. Brother XM3700 Broken Needle Replacement: adım 8, 2 resimden 2.
    • Rethread the needle and pull the thread through the back.
Sonuç
Congratulations! You have successfully replaced your broken needle. Happy sewing!
Bir başkası bu kılavuzu tamamladı.
Nadya Verick
178 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 1-6, Andersen Winter 2023 UC Davis, Team 1-6, Andersen Winter 2023 üyesi
UCD-ANDERSEN-W23S1G6
4 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 5
Son 30 gün: 20
Her zaman: 303
