Ana içeriğe geç
Brother XR-40 Stitch Select Knob Replacement
Neye ihtiyacın var
  1. Brother XR-40 Stitch Select Knob Replacement, Back Panel: adım 1, 1 resimden 1.
    • Place the machine on a solid surface.
    • Remove the 14mm Phillips #2 screw holding on the face cover.
  2. Brother XR-40 Stitch Select Knob Replacement: adım 2, 1 resimden 1.
    • Remove the two 14mm Phillips #2 screws and two 22mm Phillips #2 screws that secure the rear casing.
  3. Brother XR-40 Stitch Select Knob Replacement: adım 3, 1 resimden 1.
    • Lay the machine on its side.
    • Remove the four 10mm Phillips #2 screws that hold the bottom panel in place.
    • The feet will come off with the screws.
  4. Brother XR-40 Stitch Select Knob Replacement: adım 4, 1 resimden 1.
    • Remove the bottom panel.
  5. Brother XR-40 Stitch Select Knob Replacement: adım 5, 1 resimden 1.
    • Place the machine upright.
    • Remove the rear casing.
    • You may have to wiggle the panel and pull at the same time.
  6. Brother XR-40 Stitch Select Knob Replacement, Stitch Select Knob: adım 6, 1 resimden 1.
    • Adjust the knob to gain access to the phillips head screw.
  7. Brother XR-40 Stitch Select Knob Replacement: adım 7, 1 resimden 1.
    • Remove the 14mm Phillips #2 screw.
  8. Brother XR-40 Stitch Select Knob Replacement: adım 8, 1 resimden 1.
    • Remove the knob.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Bickers
673 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-12, Amido Winter 2014 Cal Poly, Team 2-12, Amido Winter 2014 üyesi
CPSU-AMIDO-W14S2G12
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 21
Her zaman: 1,464
