Ana içeriğe geç
Brown multipractic timing belt replacement
Neye ihtiyacın var
  1. Brown multipractic timing belt replacement, toothed belt: adım 1, 1 resimden 1.
    • Remove the stirring container.
    • Turn the machine upside down
  2. Brown multipractic timing belt replacement: adım 2, 2 resimden 1. Brown multipractic timing belt replacement: adım 2, 2 resimden 2.
    • Sometimes the screws are hidden under the rubber feet. Then you have to pull them out.
  3. Brown multipractic timing belt replacement: adım 3, 2 resimden 1. Brown multipractic timing belt replacement: adım 3, 2 resimden 2.
    • Unscrew the screws on the bottom plate.
    • Take off the bottom plate.
  4. Brown multipractic timing belt replacement: adım 4, 2 resimden 1. Brown multipractic timing belt replacement: adım 4, 2 resimden 2.
    • Clearly visible: the timing belt is touched!
    • The timing belt size is printed. In this model multipractic it is one of the type 190 XL 037.
    • With the right name it is easy to buy.
  5. Brown multipractic timing belt replacement: adım 5, 1 resimden 1.
    • The new belt is laid on. First on the small drive wheel, then on the large drive wheel, sit there on one side and spin once.
Sonuç
Repeat the steps in reverse order to reassemble your device.
2 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
de en
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
VauWeh
248.326 İtibar
281 adet Kılavuz yazıldı
Ekip
Repair is War on Entropy Repair is War on Entropy üyesi
Community
29 Üyeler
1.753 adet Kılavuz yazıldı
Bir Yorum
Any guide for replacing belt for Braun Fx 3030 processor
Sajith kakkattil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 30
Her zaman: 3,692
