Ana içeriğe geç
C-Clamp Sternum Strap Replacement
  1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: adım 1, 2 resimden 1. C-Clamp Sternum Strap Replacement, C-Clamp Sternum Strap Replacement: adım 1, 2 resimden 2.
    • Locate the sternum strap that has come off the pack.
    • Replacements for this style of sternum strap are not currently available, so if part or all of the sternum strap is missing, reach out to Patagonia for alternative options.
  2. C-Clamp Sternum Strap Replacement: adım 2, 3 resimden 1. C-Clamp Sternum Strap Replacement: adım 2, 3 resimden 2. C-Clamp Sternum Strap Replacement: adım 2, 3 resimden 3.
    • The 'c-clamp' piece of the sternum strap fits over a plastic tube or ‘rail’ that is inside the backpack strap. At the bottom of this rail there is a fabric flap.
    • Pull back the fabric flap to expose where the rail ends. This is where the c-clamp was designed to be slid on and off.
    • At the exposed area at the base of the rail, slide the c-clamp back onto the rail.
    • Pull tightly on the fabric flap to expose the area.
    • Maneuver as if parallel parking a car. Start at an angle, slide partially onto the rail, and then straighten out.
    • This can be difficult to do, don’t be shy using some muscle!
    • Repeat the steps above on the other backpack strap.
  3. C-Clamp Sternum Strap Replacement: adım 4, 2 resimden 1. C-Clamp Sternum Strap Replacement: adım 4, 2 resimden 2.
    • Slide the sternum strap to your desired position.
    • Hit the trails with your newly attached sternum strap!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Zach Mueller
1.504 İtibar
8 adet Kılavuz yazıldı
2Kılavuz Yorumları
This is helpful, except where do I find the replacement part! I contacted Patagonia and they no longer make it; they said to try a local sporting goods store or to send to Patagonia and they'll sew on a new daisy-chain version. My local REI does not have these parts either. Bummer!
Jornywar - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 27
Son 30 gün: 119
Her zaman: 2,662
