Ana içeriğe geç
C-shaped Shower Door Handle Replacement
Neye ihtiyacın var
  1. C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: adım 1, 3 resimden 1. C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: adım 1, 3 resimden 2. C-shaped Shower Door Handle Replacement, C-shaped Shower Door Handle: adım 1, 3 resimden 3.
    • Locate the socket head cap screw on the bottom arm of one door handle.
    • Only one handle will have the cap screws—one on the top and one on the bottom arm.
    • Insert the Allen wrench into the cap screw hole.
    • Rotate the Allen wrench counterclockwise to loosen the screw.
  2. C-shaped Shower Door Handle Replacement: adım 2, 2 resimden 1. C-shaped Shower Door Handle Replacement: adım 2, 2 resimden 2.
    • Once the screw has been loosened, gently pull the handle away from the door.
  3. C-shaped Shower Door Handle Replacement: adım 3, 1 resimden 1.
    • Repeat steps 1 and 2 for the top of the handle.
    • Carefully remove the handle.
  4. C-shaped Shower Door Handle Replacement: adım 4, 2 resimden 1. C-shaped Shower Door Handle Replacement: adım 4, 2 resimden 2.
    • On the remaining handle, insert the Phillips #2 screwdriver into the bottom screw.
    • Turn the screwdriver counterclockwise to loosen the screw.
    • Remove the screw cap, screw, and washer.
    • There may be several parts to the screw and washer set. This example has a brass screw cap, a screw, a larger 1.25" metal washer and plastic washer, and the interior, 3/4" plastic washer.
  5. C-shaped Shower Door Handle Replacement: adım 5, 1 resimden 1.
    • Disassemble the screw and washer set.
    • Remove the old or damaged interior plastic washer and discard.
  6. C-shaped Shower Door Handle Replacement: adım 6, 3 resimden 1. C-shaped Shower Door Handle Replacement: adım 6, 3 resimden 2. C-shaped Shower Door Handle Replacement: adım 6, 3 resimden 3.
    • Slide the new plastic washer onto the screw.
    • This may require threading the washer onto the screw if the hole is snug.
    • After you have threaded the new washer, reassemble the remaining parts of the screw set in reverse order.
  7. C-shaped Shower Door Handle Replacement: adım 7, 2 resimden 1. C-shaped Shower Door Handle Replacement: adım 7, 2 resimden 2.
    • Insert the threaded screw set back through the shower door and handle.
    • Tighten the screw with the Phillips screwdriver, taking care not to overtighten or strip the screw.
  8. C-shaped Shower Door Handle Replacement: adım 8, 1 resimden 1.
    • Repeat steps 4-7 with the top screw.
  9. C-shaped Shower Door Handle Replacement: adım 9, 2 resimden 1. C-shaped Shower Door Handle Replacement: adım 9, 2 resimden 2.
    • Once both screws are tightened, slide the other handle back onto the screws.
  10. C-shaped Shower Door Handle Replacement: adım 10, 2 resimden 1. C-shaped Shower Door Handle Replacement: adım 10, 2 resimden 2.
    • Tighten the cap screw on the top part of the handle with the Allen wrench.
  11. C-shaped Shower Door Handle Replacement: adım 11, 1 resimden 1.
    • Repeat with the bottom cap screw.
  12. C-shaped Shower Door Handle Replacement: adım 12, 1 resimden 1.
    • Test both sides of the handle by gripping each one and gently pulling them back and forth.
    • If the handle is properly secure, there should be no movement.
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 60
