Ana içeriğe geç
C. BLV NeoPixel Board
Neye ihtiyacın var
  1. C. BLV NeoPixel Board, Flashing the NeoPixel Board: adım 1, 1 resimden 1.
    • Disconnect the TX/RX wires from the Duet.
    • After downloading and installing the CH340 Driver from the FYSTEC Github
    • Add a jumper to "UVCC to 5V". If you skip this step you will not be able to flash the board.
    • Download the sketch from Github and extract the zip file. Open it in Arduino IDE
    • Board is "Arduino Pro or Pro Mini"
    • Processor is "ATmega328P (5V, 16 MHz)"
    • Upload the sketch to the board
    • When upload is complete, remove the jumper.
  2. C. BLV NeoPixel Board, NeoPixel Rings: adım 2, 2 resimden 1. C. BLV NeoPixel Board, NeoPixel Rings: adım 2, 2 resimden 2.
    • Left(Heatbed) connects to port #3 on the BLV NeoPixel board
    • Middle(Hotend) connects to port #1 on the BLV NeoPixel board
    • Right(print status) connects to port #2 on the BLV NeoPixel board
  3. C. BLV NeoPixel Board, Errors Opening Sketch: adım 3, 3 resimden 1. C. BLV NeoPixel Board, Errors Opening Sketch: adım 3, 3 resimden 2. C. BLV NeoPixel Board, Errors Opening Sketch: adım 3, 3 resimden 3.
    • You might receive an error saying you need "NeoPixel_BLV.ino needs to be in a folder named NeoPixel_BLV". You have 2 options.
    • This will create a new folder and move the sketch into the newly created folder. Click OK than close Arudino IDE. Move the highlighted files and folder into the new folder "NeoPixel_BLV". You can now reopen the sketch and it should compile without issue.
    • You can also rename the sketch's parent folder to "NeoPixel_BLV". When you open the sketch you won't receive the error.
  4. C. BLV NeoPixel Board, Duet 3 Usage: adım 4, 2 resimden 1. C. BLV NeoPixel Board, Duet 3 Usage: adım 4, 2 resimden 2.
    • Because the CH340 drives RX to ~4.5v it doesn't communicate with the Duet 3. To remedy this you need to either cut the trace or de-solder the pad on the CH340(green) or on the ATMega(red). I would suggest de-soldering the pad on the CH340 because it's easier.
    • In addition to the current wiring schematic you'll also need to to connect the TX from the Arduino to RX on the duet
    • Arduino RX > Duet 3 io1.out
    • Arduino TX > Duet 3 io1.in
    • Arduino GND > Duet 3 io1.GND
    • After the modifications you will no longer be able to upload a sketch using the USB port. You have to use a FTDI serial adapter and connect it to the 6 header pins next to the USB port.
    • For firmware versions prior to RRF 3.4.
    • If using IO_0: M575 P1 S1 B57600.
    • If using IO_1: M575 P2 S1 B57600
    • For firmware versions RRF 3.4 and later
    • If using IO_0: M575 P1 S0 B57600.
    • If using IO_1: M575 P2 S0 B57600
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
David Husolo
9.162 İtibar
33 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 27
Her zaman: 2,309
