Giriş
This guide will show you how to replace your CASIO CDP-230R keys, move them to remove anything jamming your keys, or to move them to clean them.
Neye ihtiyacın var
Flip the keyboard upside down, with the keys on a flat surface.
Remove the three black 14mm Japanese Industrial Standard (J) head screws using a J1 screwdriver on the top half of the outermost side panel.
Place a hand on the front panel and speakers and carefully flip the keyboard over with the keys facing up.
Grab the center of the front panel with two hands and lift to remove panel.
Grab the speakers from the sides and lift to remove. Once you have done this for the first speaker, repeat with the second speaker.
Locate the three screws behind the keys (left, center, and right).
Remove these 10mm J screws using a J1 screwdriver.
Grasp the white ribbon lined with foam and pull up to remove from the main circuit board.
To reassemble your device, follow step 13 and then the rest of the instructions in reverse order.
13 farklı kişi bu kılavuzu tamamladı.
11Kılavuz Yorumları
Thankyou very much - I have a CDP-200R that I had to pull apart - yours was the only post I could find that helped me decode what it took!
Me too, I have 200R need to replace the keys, but afraid to dismantle , now you save us all.thank you
Searched everywhere on how to fix my Casio CDP-220RBK and this was all I could find that actually helped! Awesome and very helpful guide!!!
Thanks a lot. This manual is very detailed, and the only one I've found in the whole Internet.
Hello,
One of my kids lifted a black key from my piano. It won't come down fully and doesn't play when pressed. It's also harder to press, with more resistance.
Will I be able to put it back in place by following these instructions?
Many thanks.
