Ana içeriğe geç
CASIO fx-300 MS Battery Replacement
Neye ihtiyacın var
  1. CASIO fx-300 MS Battery Replacement, Battery: adım 1, 3 resimden 1. CASIO fx-300 MS Battery Replacement, Battery: adım 1, 3 resimden 2. CASIO fx-300 MS Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Press SHIFT+AC to turn off the calculator.
    • Press the shift button, and a symbol in the top-left corner should appear. Afterward, push the AC button.
  2. CASIO fx-300 MS Battery Replacement: adım 2, 3 resimden 1. CASIO fx-300 MS Battery Replacement: adım 2, 3 resimden 2. CASIO fx-300 MS Battery Replacement: adım 2, 3 resimden 3.
    • Flip the calculator so the back of the device is facing up.
    • Use a Phillips #0 screwdriver to remove the six 5 mm screws.
  3. CASIO fx-300 MS Battery Replacement: adım 3, 3 resimden 1. CASIO fx-300 MS Battery Replacement: adım 3, 3 resimden 2. CASIO fx-300 MS Battery Replacement: adım 3, 3 resimden 3.
    • Use a spudger to pry the back case from the calculator.
    • Gently work your way around the edge of the calculator to release any clips before separating the two halves.
    • If you feel resistance when removing the back case, check to make sure you didn't miss a screw.
  4. CASIO fx-300 MS Battery Replacement: adım 4, 3 resimden 1. CASIO fx-300 MS Battery Replacement: adım 4, 3 resimden 2. CASIO fx-300 MS Battery Replacement: adım 4, 3 resimden 3.
    • Use a spudger to remove the old battery.
    • Replace it with a new LR44 1.5 volt battery.
  5. CASIO fx-300 MS Battery Replacement: adım 5, 3 resimden 1. CASIO fx-300 MS Battery Replacement: adım 5, 3 resimden 2. CASIO fx-300 MS Battery Replacement: adım 5, 3 resimden 3.
    • Reassemble the calculator and replace the 5 mm Phillips #0 screws.
    • Press the ON button to verify that the replacement was successful.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Raphael Tweneboah
145 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 59
Her zaman: 968
