Ana içeriğe geç
CASIO fx-570MS Battery Replacement
Neye ihtiyacın var
  1. CASIO fx-570MS Battery Replacement, charger: adım 1, 2 resimden 1. CASIO fx-570MS Battery Replacement, charger: adım 1, 2 resimden 2.
    • Flip the calculator over so the bottom is facing upwards.
    FixBot'a Sor
    Yorum Ekle
  2. CASIO fx-570MS Battery Replacement: adım 2, 3 resimden 1. CASIO fx-570MS Battery Replacement: adım 2, 3 resimden 2. CASIO fx-570MS Battery Replacement: adım 2, 3 resimden 3.
    • Remove the screw from the battery hatch on the top-right corner using a 1.5 mm slotted screwdriver.
    • Remove the battery hatch.
    FixBot'a Sor
    Yorum Ekle
  3. CASIO fx-570MS Battery Replacement: adım 3, 3 resimden 1. CASIO fx-570MS Battery Replacement: adım 3, 3 resimden 2. CASIO fx-570MS Battery Replacement: adım 3, 3 resimden 3.
    • Insert a spudger into the dent to the left of the battery until it hits the bottom of the panel board.
    • To create leverage, gently push the spudger towards the bottom of the battery (pushing your hand downwards and towards the back cover if necessary) to lift the battery out of its compartment.
    • Caution: Be careful to not rupture the battery or damage the panel board.
    FixBot'a Sor
    Yorum Ekle
  4. CASIO fx-570MS Battery Replacement: adım 4, 3 resimden 1. CASIO fx-570MS Battery Replacement: adım 4, 3 resimden 2. CASIO fx-570MS Battery Replacement: adım 4, 3 resimden 3.
    • When you insert the new battery into the battery compartment, it should remain bulged upwards on the side towards the dent.
    • Make sure the flat side of the battery is facing upwards.
    • To finish inserting the new battery into the battery compartment, gently press the bulged corner with your finger until it slides into place.
    FixBot'a Sor
    Yorum Ekle
  5. CASIO fx-570MS Battery Replacement: adım 5, 2 resimden 1. CASIO fx-570MS Battery Replacement: adım 5, 2 resimden 2.
    • Close the plastic hatch and secure the screw.
    FixBot'a Sor
    Yorum Ekle
  6. CASIO fx-570MS Battery Replacement: adım 6, 2 resimden 1. CASIO fx-570MS Battery Replacement: adım 6, 2 resimden 2.
    • Flip the calculator on its back and press the 'ON' button to power it up.
    • A zero will appear on the bottom right corner of the LED display.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Your beloved CASIO fx-570MS Scientific Calculator is good to go for another few years.
3 farklı kişi bu kılavuzu tamamladı.
Saquib Ahmed
205 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
How much does the battery cost?
Tamanna - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 11
Son 7 gün: 71
Son 30 gün: 289
Her zaman: 57,597
