Ana içeriğe geç
CHI Original Power Cord Replacement
Neye ihtiyacın var
  1. CHI Original Power Cord Replacement, Hinge Spring: adım 1, 2 resimden 1. CHI Original Power Cord Replacement, Hinge Spring: adım 1, 2 resimden 2.
    • Insert a nylon or metal spudger under the plastic CHI spring covers. Pry them up to pop them off. Do this for each side.
  2. CHI Original Power Cord Replacement: adım 2, 1 resimden 1.
    • Remove the .53" long screw from the hinge pin.
  3. CHI Original Power Cord Replacement: adım 3, 1 resimden 1.
    • Remove the hinge pin.
  4. CHI Original Power Cord Replacement: adım 4, 1 resimden 1.
    • Separate the two halves of the CHI Original.
  5. CHI Original Power Cord Replacement: adım 5, 2 resimden 1. CHI Original Power Cord Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the spring pin with a pair of pliers or tweezers.
    • Remove the spring.
  6. CHI Original Power Cord Replacement, Power Cord: adım 6, 2 resimden 1. CHI Original Power Cord Replacement, Power Cord: adım 6, 2 resimden 2.
    • Remove (2) .31" Phillips head screws from back cover.
    • Remove cover.
  7. CHI Original Power Cord Replacement: adım 7, 1 resimden 1.
    • Gently pull upwards on the connection point and disconnect the power cord.
Sonuç
Eric Knigga
215 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G2, Freund Fall 2017 IUPUI, Team S1-G2, Freund Fall 2017 üyesi
IUPUI-FREUND-F17S1G2
4 Üyeler
3 adet Kılavuz yazıldı
5 Yorum
Do you know where to get a replacement power cord?
Taylor Bradford - Yanıt
How/where do you purchase the replacement cord?
fixitman - Yanıt
Where do you order an actual cord from??
Kelly Hickman - Yanıt
Where we can get Power Cord?
Nazim - Yanıt
Bonjour Nazim, j'ai trouvé le bon câble pour réparer le modèle GF1001EUN Farouk Systems USA sur le site web de pgservice :
Hi Nazim, I found the right cable to repair the GF1001EUN Farouk Systems USA model on the pgservice website :
https://pgservice.cc/fr/products/gammapi...
Sonny -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 35
Son 30 gün: 94
Her zaman: 6,244
