Ana içeriğe geç
CHI Spin N Curl Rotating Curler Directional Buttons Replacement
Neye ihtiyacın var
  1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Power Cord: adım 1, 1 resimden 1.
    • Use a metal spudger to pry off the silver, shiny trim.
  2. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 2, 1 resimden 1.
    • Remove inner black housing of the CHI Spin N Curl using the metal spudger to pop it out.
  3. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 3, 2 resimden 1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 3, 2 resimden 2.
    • Use a 2 mm flathead to remove the two screws.
  4. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 4, 2 resimden 1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 4, 2 resimden 2.
    • Use a metal spudger to pry open the seams of the device.
  5. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 5, 3 resimden 1. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 5, 3 resimden 2. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 5, 3 resimden 3.
    • Toward the bottom of the device, grab the swivel power cord.
    • Gently pull the power cord to detach it from the CHI Spin N Curl
    • Replace the faulty cord when the original cord has been removed.
  6. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Motherboard: adım 6, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the screws holding the barrel in.
  7. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 7, 1 resimden 1.
    • Remove the screws using Phillips #00 screwdriver and take off the components.
    • Once all screws are removed, take out the barrel accessing the motherboard underneath.
  8. CHI Spin N Curl Rotating Curler Directional Buttons Replacement: adım 8, 1 resimden 1.
    • Using metal spudger, lift and remove the motherboard and disconnect the top components.
  9. CHI Spin N Curl Rotating Curler Directional Buttons Replacement, Directional Buttons: adım 9, 1 resimden 1.
    • After the motherboard is removed, use the metal spudger to push and remove the directional buttons, and wipe underneath with a slightly damp alcohol cotton pad.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Annalise White
530 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-7, Petersen Fall 2022 UMass Dartmouth, Team 2-7, Petersen Fall 2022 üyesi
UMASSD-PETERSEN-F22S2G7
3 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 25
Her zaman: 426
