Ana içeriğe geç
CHUWI GemiBook XPro Speakers Replacement
Neye ihtiyacın var
  1. CHUWI GemiBook XPro Speakers Replacement, Battery: adım 1, 2 resimden 1. CHUWI GemiBook XPro Speakers Replacement, Battery: adım 1, 2 resimden 2.
    • Peel off the black tape on the upper-right side of the motherboard.
  2. CHUWI GemiBook XPro Speakers Replacement: adım 2, 2 resimden 1. CHUWI GemiBook XPro Speakers Replacement: adım 2, 2 resimden 2.
    • Use two opening tools or your fingernails to carefully "walk" the battery connector out of its socket.
  3. CHUWI GemiBook XPro Speakers Replacement: adım 3, 3 resimden 1. CHUWI GemiBook XPro Speakers Replacement: adım 3, 3 resimden 2. CHUWI GemiBook XPro Speakers Replacement: adım 3, 3 resimden 3.
    • Unseat the speaker wires and antenna wire from their retaining hooks on the battery with a halberd spudger.
  4. CHUWI GemiBook XPro Speakers Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #1 screwdriver to remove the five 4.3 mm screws that secure the battery.
  5. CHUWI GemiBook XPro Speakers Replacement: adım 5, 3 resimden 1. CHUWI GemiBook XPro Speakers Replacement: adım 5, 3 resimden 2. CHUWI GemiBook XPro Speakers Replacement: adım 5, 3 resimden 3.
    • Lift the battery up and out of the chassis.
  6. CHUWI GemiBook XPro Speakers Replacement, Speakers: adım 6, 2 resimden 1. CHUWI GemiBook XPro Speakers Replacement, Speakers: adım 6, 2 resimden 2.
    • Use tweezers or your fingernails to gently disconnect the speaker connector.
  7. CHUWI GemiBook XPro Speakers Replacement: adım 7, 3 resimden 1. CHUWI GemiBook XPro Speakers Replacement: adım 7, 3 resimden 2. CHUWI GemiBook XPro Speakers Replacement: adım 7, 3 resimden 3.
    • Use a Phillips #1 screwdriver to remove the four 4.2 mm screws that secure the speakers (two screws on each speaker).
  8. CHUWI GemiBook XPro Speakers Replacement: adım 8, 2 resimden 1. CHUWI GemiBook XPro Speakers Replacement: adım 8, 2 resimden 2.
    • Gently pick up and remove both speakers. Be careful not to strain the wire connecting them.
Sonuç
JakeV
407 İtibar
3 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 51
