Ana içeriğe geç
CM Storm QuickFire Rapid Large Keycap Replacement
Neye ihtiyacın var
    1. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: adım 1, 3 resimden 1. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: adım 1, 3 resimden 2. CM Storm QuickFire Rapid Large Keycap Replacement, Remove surrounding keycaps: adım 1, 3 resimden 3.
      FixBot'a Sor
      Yorum Ekle
    2. CM Storm QuickFire Rapid Large Keycap Replacement: adım 2, 1 resimden 1.
      • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
      FixBot'a Sor
      Yorum Ekle
    3. CM Storm QuickFire Rapid Large Keycap Replacement: adım 3, 3 resimden 1. CM Storm QuickFire Rapid Large Keycap Replacement: adım 3, 3 resimden 2. CM Storm QuickFire Rapid Large Keycap Replacement: adım 3, 3 resimden 3.
      • Install the plastic rings on the new keycap. The overhang needs to be ‘facing forward’ so that when the keycap is placed back on the board, the overhang is furthest away from you. When attaching the new key to the board, the ends of the metal bar on the board will go through these rings.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Shiva Empranthiri
781 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G23
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 6,268
