Giriş
This guide will go over how to install O-rings on smaller keys on your keyboard.
Aletler
Parçalar
  1. Insert the keycap puller around the key you'd like to install an O-ring under.
    • Insert the keycap puller around the key you'd like to install an O-ring under.
  2. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  3. Pull cap directly upward.
    • Pull cap directly upward.
  4. Place an O-ring around the plastic shaft located on the underside of the keycap.
    • Place an O-ring around the plastic shaft located on the underside of the keycap.
Sonuç
2 başka kişi bu kılavuzu tamamladı.
Shiva Empranthiri
736 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G23
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 1
Son 30 Gün: 11
Her zaman: 736
