Giriş
This guide will go over how to install O-rings on the backspace, spacebar, shift, and enter keys on your keyboard.
  1. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide. Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide.
  2. Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. Pro Tech Toolkit içeren veya $100,00tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  4. Remove the plastic rings from the keycap. Remove the plastic rings from the keycap. Remove the plastic rings from the keycap.
    • Remove the plastic rings from the keycap.
  5. Place the O-rings around the nubs underneath the keycap at each circled locations. Place the O-rings around the nubs underneath the keycap at each circled locations.
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shiva Empranthiri
736 İtibar
4 adet Kılavuz yazıldı
Takım
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G23
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Yanıt
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 4
Her zaman: 1,108
