Giriş
This guide will go over how to install O-rings on the backspace, spacebar, shift, and enter keys on your keyboard.
Neye ihtiyacın var
Remove keycaps surrounding the key you'd like to install an O-ring under by following the remove small keycaps guide.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
