Ana içeriğe geç
CM Storm QuickFire Rapid O-ring: Large Keycap Installation
Neye ihtiyacın var
  1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: adım 1, 3 resimden 1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: adım 1, 3 resimden 2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation, O-ring: Large Keycap: adım 1, 3 resimden 3.
  2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: adım 2, 1 resimden 1.
    • Pull the large keycap upward with your fingers until the cap separates from the plastic rings underneath the cap. If the metal bar beneath the cap comes loose during removal, snap it back in place.
  3. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: adım 3, 3 resimden 1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: adım 3, 3 resimden 2. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: adım 3, 3 resimden 3.
    • Remove the plastic rings from the keycap.
  4. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: adım 4, 2 resimden 1. CM Storm QuickFire Rapid O-ring: Large Keycap Installation: adım 4, 2 resimden 2.
    • Place the O-rings around the nubs underneath the keycap at each circled locations.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Shiva Empranthiri
781 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-23, Maness Fall 2014 Cal Poly, Team 6-23, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G23
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Best choice if you want all the “click” but none of the “clack” on your mechanical keyboard
Cherry Mx Black Rubber O-rings (125 pcs -EPDM – 40A) €3,98
Cherry Mx Black Rubber O-rings (90 pcs -EPDM – 40A) €3,48
[NL] O-rings Webstore http://tigri.bigcartel.com
Specs
Material: EPDM Industrial Grade Rubber
Color: Black
Hardness: 40A
Thickness: 1,50 mm (0.059 in)
Packaging: 125 pcs/bag or 90 pcs/bag
tigriorings - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 14
Her zaman: 1,935
