Ana içeriğe geç
CR-10S PRO Y Axis Linear Rail Kit Installation
Neye ihtiyacın var
  1. CR-10S PRO Y Axis Linear Rail Kit Installation, Machine Prep for linear rail kit: adım 1, 1 resimden 1.
    • Remove Bed leveling knobs
    • Be careful when lifting the bed off the Y Carriage. The springs may fall when lifting the bed up.
    • Lift bed and set to the back left side of the printer
  2. CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: adım 2, 3 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: adım 2, 3 resimden 2. CR-10S PRO Y Axis Linear Rail Kit Installation, Frame Bolts Swap: adım 2, 3 resimden 3.
    • Note: uses the stock CR10S Pro Y carriage with Vslot wheels assembly to keep the rails aligned while replacing the frame bolts
    • Remove with M5X30 SHCS one at a time
    • Replace with M5X30 BHCS
    • Slide Y carriage off from the front of the machine
  3. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Prep Instructions: adım 3, 1 resimden 1.
    • Remove from packaging
    • Note, do not touch the rail directly with your hands.
    • Wipe down rail with a lint free cloth
    • Add grease to the grease port on each side of the rail
  4. CR-10S PRO Y Axis Linear Rail Kit Installation: adım 4, 3 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation: adım 4, 3 resimden 2. CR-10S PRO Y Axis Linear Rail Kit Installation: adım 4, 3 resimden 3.
    • Pre-insert Spring loaded and use an Allen wrench or screwdriver to help align
    • M3 Spring loaded T-nut
    • Use the circled Rail mounting positions
    • 16x M3x8 SHCS
    • Picture with MGN guide on rail
  5. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: adım 5, 2 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail Adapter Plate install: adım 5, 2 resimden 2.
    • Tighten the screws evenly in an X shape
    • 4x Adapter Plate
    • 16x M3x6 FHCS
  6. CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: adım 6, 3 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: adım 6, 3 resimden 2. CR-10S PRO Y Axis Linear Rail Kit Installation, Stock Y carriage Plate Prep: adım 6, 3 resimden 3.
    • Remove all Vslot wheels and bolts
    • Install endstop Trigger at this location
    • Picture 2 shows endstop Trigger install
    • M5x35 SHCS
    • 3x Stock Vslot wheel spacers
    • M5 Nylon Ring Lock Nut
  7. CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: adım 7, 3 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: adım 7, 3 resimden 2. CR-10S PRO Y Axis Linear Rail Kit Installation, Y Carriage Plate install: adım 7, 3 resimden 3.
    • Belt mounting holes goes on the right side of the priter
    • Left side screws
    • Some early kits are drilled and taped for M5 Screws. The M4x8 FHCS is substituted for a M5x10 FHCS and the M4x10 BHCS substituted for M5x10 BHCS.
    • 2x M4x8 FHCS
    • Right screw stack order
    • M4x10 BHCS - M4 washer - M4 Large OD washer
    • Tightened the left side screws first
  8. CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: adım 8, 3 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: adım 8, 3 resimden 2. CR-10S PRO Y Axis Linear Rail Kit Installation, Belt spacer install: adım 8, 3 resimden 3.
    • Belt Bracket Spacer
    • 2x M4x20 SHCS
  9. CR-10S PRO Y Axis Linear Rail Kit Installation, Endstop Braket mounting hardware Change: adım 9, 1 resimden 1.
    • Remove the stock endstop bracket screw
    • Replace endstop bracket mount screw with:
    • M3x10 SHCS, M3 Washer and M3 Sliding tnut
  10. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: adım 10, 2 resimden 1. CR-10S PRO Y Axis Linear Rail Kit Installation, Rail stopper install: adım 10, 2 resimden 2.
    • M5*10 BHCS
    • Acrylic stopper
  11. CR-10S PRO Y Axis Linear Rail Kit Installation, EndStop adjustment: adım 11, 1 resimden 1.
    • Adjust the Endstop position by sliding the endstop back until the nozzle tip lines up with the front edge of the bed when the endstop triggers.
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
AJ Pereira
2.707 İtibar
16 adet Kılavuz yazıldı
Ekip
Tiny Machines 3D Tiny Machines 3D üyesi
Community
5 Üyeler
41 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 13
Son 30 gün: 64
Her zaman: 4,086
