Neye ihtiyacın var
Labeled bags are used in the following steps
Hardware
Power Supply Fan (Step 4)
Rear Case Exhaust Fan(Step 5)
Control Board Fan Assembly (Step 6)
Using a #1 Phillips screwdriver, remove the 11 screws on the bottom and 2 screws on each side for a total of 15
Next, remove the bottom cover
With the bottom cover removed, turn the printer sideways and remove the power supple unit (PSU) screws while holding the PSU in place ribbon cable side up
Remove the 6 PSU screws securing the cover (circled in blue)
Next, remove the 2 screws securing the original 4020 Fan (circled in red)
Unplug the original fan cable
Original fan cable is glued down. Gently, pull up on the cable to remove after you unplug the connector
Route the new fan cable under the white wires
Plug in new fan cable
Mount fan with Self tapping screws included in the kit
Pay attention to the fan orientation and wire placement
Follow step 2 in reverse for reinstallation of the PSU cover
Included Nylon standoffs replace control board mounting screws
Place the Control Fan Assembly as shown
Use the previously remove M3 screws to secure the 3D printed fan mount to the standoffs.
Plug in Fan adapter cable
8Kılavuz Yorumları
I would like to know where the parts kit can be purchased as well, either that or a list of part numbers.
You can email us at support@tinymachines3d.com to order a kit
Does this apply to v2
Yes, it does apply to the CR10S Pro V2 as well
